hi am new to this site and hello to everyone 😉
i just got a 6600 and i want to set it up for emails but i dont know how to,
anyone got a step by step guide
i have a hotmail,gmail,yahoo accounts (gmail would b good or yahoo)
i am also on 02-uk pay as u go
please if anyone could help, that would be so nice of u,
thanx
If you search for posts that have all the words "POP3", "IMAP4", "SMTP", "WAP", "GPRS", "internet", "access" and "point" you should find at least a few posts where it has been explained in more or less detailed fashion (you can also add me to the author field to get better hits, since I know I've explained this several times): http://www.allaboutsymbian.com/forum/search.php?
Note: Hotmail doesn't support Internet protocols (POP3/IMAP4 and SMTP) for email access, so it won't work.
Niether will gmail because it requires ssl authentication and the 6600 dosen't support it however you can accsess gmail using profimail...
or if you go to http://www.o2.co.uk/register_pop.html and sign up for a free account you will get 20 meg of space and you can accsess this using your phone.... after you do this if you require the sttings then let me know and i'll give you them...
I could do with those settings if you'd be so kind
thx 😊
hey
i signed up for bluebottle email, i put the settings in as pop3 in and out going put in as mail.bluebottle.com (gprs connection and not mms)
once i put the settings in, i tryed CONNECTing to it to see if i could get to my emails, but it goes as far as connectiong via gprs (o2) and donesnt connect 😡
have i did something wrong with my settings or is it o2 that is playing up
thanks for any help
the settings are as follows:
[INDENT]mailbox name: what ever you want to call it ie, o2.
Access point: o2 gprs.
email address: this is your username followed by @o2.co.uk ie, [email][email protected][/email].
Outgoing mail server: smtp.o2.co.uk.
send message: immediatly.
user name: this is the same as email address ie, [email][email protected][/email].
password: your o2 password.
incoming mail server: mail.o2.co.uk.
mailbox type: pop3.
secruity: off.
apop secure login: off.
[/INDENT]
