bluetooth head phones by toshiba
2 replies · 2,391 views · Started 08 May 2005
Probably not. The specs says Bluetooth 1.2 or higher is required. The N-Gage is based on Bluetooth 1.1 (and I suspect these headphones also require the Bluetooth A2DP profile, Advanced Audio Distribution Profile).
N/A wrote:Probably not. The specs says Bluetooth 1.2 or higher is required. The N-Gage is based on Bluetooth 1.1 (and I suspect these headphones also require the Bluetooth A2DP profile, Advanced Audio Distribution Profile).
does this mean they wont work at all,or you talking just about the remote???
do you know bout the HP ones what about them do they work on the n-gage?
