solved all problems so far. all programs back in and data secure.
now when i start the phone, i always get this error
application closed
application SW_SA_Daemon_UI
reason code E32USER_CBase
reason number 44
what program might this be that ill just remove it and put it back again.
Format the device and re-install the OS again , i belive it hasn,t been installed properly
dude, are you sure its the os and not just one program fugging up?
ive been installing over and over with the bloody serial cable and its painful.
What was the RAE Ver.?
With a clean device do you get this message?
nope. this is a new thing. reformatted it all. installed some progs. restarted again cause phone slowing down. install again. then on the final restart, i got the message after i restarted
I have made a GPRS site for MailServer for all Java enable mobile.When I access this site using Sony Ericsson P910i then there is E32USER_CBase Reason-21 is appear.Please help me..How to remove this problem. U can access this site through http://mobile.xgen.in URL.
Please help me. U can contect me Using MSN Messenger.
MY ID is:[email protected]
It will appericate me.
UmaShankar
