Hallo please help! There is alot of dust on my screen that i relly want to clean of! 😉
How can i take the front cover of my 6630?!
6630 is "Xpress on" cover so it's easy.
Simply a matter of removing battery cover then un clipping front cover at the top.
It should then fall away from phone.
Do not try and remove cover from bottom or sides as this could damage fascia.
It seems to hook in at bottom and clip over at top.
You'll see what i mean when ya take it off.
lunatique wrote:6630 is "Xpress on" cover so it's easy.
Ohh THANKS! Your right! It was SOOOO easy! 😮
