JoyKick is a new piece of software for the Nokia 7650. It allows you to use the joystick to input data. The idea is based on the sucessful JoyCalc program by the same author Kylom.
Authors Text:
You want to make a phone call to a person, who is number 50 down in your list of contacts? Open Contacts and now you have a choice: either you push the joystick down 50 times, or you have to open the keypad and enter the first letters of her name. Not so if JoyKick is running in the background: press the joystick twice quickly and a virtual keyboard pops up, where you can "type" the letters with a minimal number of joystick actions...
JoyKick supports predictive text input and numbers input: it detects the input mode of the application in the background and pops up the virtual keyboard suited to the situation.
Try JoyKick now and you might find out that it is easier to use than the normal keypad, even to take notes or send emails. The only thing that you will not do without opening the keypad or your Nokia 7650 is... take pictures .
Where can i download JoyKick from???
or the authors site www.kylom.com
new version is out now with a new name:
Soft Keypad
Here is the text from the website
You want to make a phone call to a person, who is number 50 down in your list? Open Contacts and you have a choice: either you push the joystick down 50 times, or you must open the keypad and type the first letters of her name. Not so if Soft Keypad is ready in the background: press the joystick twice quickly and a virtual keyboard pops up, where you can "type" the letters with a minimal number of joystick actions... Same thing in the Phone application, where you can dial a full number and make a call, without your thumb leaving the joystick at any time!! Soft Keypad supports normal text input, predictive text input (T9) and numbers input: in most situations, it will detect the input mode of the application in the background and pop up the virtual keyboard suited to the situation. You can even switch the input mode of the device from normal text to predictive text and back with an Options command of Soft Keypad...
Try Soft Keypad now and you will find out that the joystick is easier to use than the normal keypad, even to take notes or send emails. The only thing, which you may find hard to do without opening the keypad of your Nokia 7650 is... take pictures .
http://www.kylom.com/
