Phone problems
3 replies · 1,769 views · Started 09 May 2005
Having problems with my Nokia 6600..Gallery won't open, just shows "Opening Files" but doesn't get inside the Gallery then it would show, "Application Closed Media Gallery"..opening the Menu became slower, tried to delete some of the files like games, themes, etc but no improvement. Tried every kind of reformatting codes - *#7780#, *#7370# and Green + * + 3 then power on..and after it restarted i was able to open the Gallery but after i used the phone, like personalizing the Profiles, i went back to open Gallery but it gave me the same thing "Opening Files" and still didn't open the folder. Please advice. Thanks! Btw, im a newbie. =)
hey exactly the same thing happens to me on my 6600.Its just the gallery in general as soon as you click it it just sticks on 'opening files'.I dont know what it is but i've had 3 different MMC's in mine and it still does it so its not that.
Nice avatar btw 😉
hellraiza15 wrote:hey exactly the same thing happens to me on my 6600.Its just the gallery in general as soon as you click it it just sticks on 'opening files'.I dont know what it is but i've had 3 different MMC's in mine and it still does it so its not that.
Nice avatar btw 😉
I used to have this same problem on my 6620. It was another program that I had open in the background. I think it was MobiTV...
Hope this helps..
