I am using PC Suite 6.5 to sync with Lotus v.6.5.1 but from time to time, a calendar entry is either deleted from the phone or an entry is not sync'ed over to thephone. Can anyone help?
Sync with Lotus Notes v.6.5.1
Are you using 6.5.10 (the original 6.5 release) or 6.5.12 (updated version from April 28th)?
If the former, try the latter.
Is there some kind of a pattern to this that you could detect (something common or different about these problem calendar entries)?
I am using PC Suite 6.5.12. There is no pattern to the bugs. Also, I called Nokia and they told me that PC Suite dores not support Lotus Note 6.5 eventhough the software seems to indciate it supports all 6.x versions.
