ok, ive just had it delievered, n im tryin to put the battery and sim card in but i cant get the cover off, i can get the back cover to slide part way, n then it jams, and i cant find anyway in the manual or online on how to get it off. im dying to get it going but i cant 😞 :icon4:
6630 removing the back cover. HELP!!
tarquil wrote:ok, ive just had it delievered, n im tryin to put the battery and sim card in but i cant get the cover off, i can get the back cover to slide part way, n then it jams, and i cant find anyway in the manual or online on how to get it off. im dying to get it going but i cant 😞 :icon4:
dont be afraid 😊 i had the same problem,but the online picture manual helped me... its a little bit harder,but try to do it this way... push the back cover up some centimeters,and than pick it up,but be careful 😊
try to look at this http://www.nokia.com/nokia/0,,64916,00.html and interactive dmonstrations,there is a picture guide how to get the cover off 😉
pull it
u won't break it
