PsiNT have announced a new bundle of their programs for the 7650. The bundle includes eFile Manager, Extend profiles Pro, Task Manager and World Clock Pro. New version of World Clock Pro and Extended Profiles (large improvements; standard and pro versions) have also been announced. These can be purchased via Handango.
World Clock Professional now fully supports alarms with customized sound
file.
System Tools now fully supports alarms with customized sound file
(requires Extended Profiles Professional to be installed).
Extended Profiles extends the functionality of the Nokia 7650/3650
phones with advanced user profile managing.
Extended Profiles significantly extends the customizing features
available in the standard "Profiles" application, and it allows for a
change of profile based on a given task schedule.
Extended Profiles allows you to set up the following for each profile:
- phone background picture, which can be set from any image available in
phone
- phone background may be also animated (available in the Professional
version only)
- color palette
- screen saver (if the Screen Saver application is installed, you can
choose from 11 different screen savers)
- A sound file used as an alarm, a different set of alarms for the Clock
and the Calendar (available in the Professional version only)
- autolock keypad function (available in the Professional version only)
- Bluetooth mode (available in the Professional version only)
- telephone keypad applications
Extended Profiles enables you to automatically switch the profiles of
your Nokia 7650. You can simply select the time, required profile and
weekday (daily, working days, weekend etc.) - Extended Profiles will do
the rest: switch and activate the profile automatically at the scheduled
time.
Thanks to the Extended Profiles application, you can program your phone
to change to a different profile ex. to your business (with your company
logo in the background, and toned down alarm sounds) for when you are at
work) as well as to your evening profile (with a crazy picture, and the
song of your favorite music group etc.).
Extended Profiles has a user-friendly interface.
Extended Profiles is written in C++ and is a very small application
offering variety of functions.
Extended Nokia 7650/3650 Suite is a selection of the most important
("must have"😉 productivity applications for Nokia 7650/3650.
By buying this Extended Nokia 7650/3650 Suite you pay $34.95 instead of
$61.8 - saving 45% on a purchase!
The package contains:
eFile Manager:
The Extended File Manager gives you full control over your device with
basic File Explorer functionality and more.
Basic eFileManager functions are:
- file browsing with access to all drives (including ROM)
- clipboard: copy, cut and paste of files and folders
- deleting and changing names of files and folders
- sending via Infrared, Bluetooth, MMS and e-mail
- opening files and application
- playing audio files
- searching
- properties
- detailed information about drives, folders and files
- changing attributes
- marking multiple files and/or folders to copy, send etc,
The eFileManager also has advanced functions missing in other managers
- Cleaning Up - clearing temp folders and unused system temporal files
(with full safety)
- Setting Operator Logo - you can set any Image to be your OpLogo
- Advanced Find - searching for files with:
- specific properties
- minimum and maximum size
- type (Image, Application, Installers etc.)
- predefined, often used names (*.mbm, *.rng, *.mid etc)
- Shortcuts - with one easy click you can set and access four Bookmarks
- Add to clipboard - you can add an eFileManager shortcut to clipboard
- Copy To Clipboard - you can copy text files to clipboard and paste
them in any other application
- Copying and Sending locked files ? an automatic function that allows
you to copy and send any system file
Task Manager:
The Task Manager provides many important task management functions:
closing and killing running tasks (including hidden system ones),
compressing memory, showing information about free RAM memory, resetting
and rebooting the phone, switching between running applications, adding
applications to the "Favorites" menu and many more.
With the Task Manager installed, users get more advanced control over
the phone. You can quickly close unused applications to free RAM memory,
automatically compress memory to free more resources, toggle between
active tasks and use Favorites not only for links to documents, but also
to all installed applications.
Extended Profiles Professional:
time.
World Clock Professional:
World Clock is not only a graphic clock with database of over 1150
locations worldwide, but it also allows you to add and edit cities and
territories and manage up to 8 alarms (Pro version). The program
displays detailed information about home and destination city (current
time, date, time offset, distance, prefix etc).
You can browse a huge database of cities and countries and see their
locations on the built-in world map, check prefixes, time and other
useful information. You can use the World Clock to quickly check what
time it is in the home city of a friend you are just going to call. With
World Clock, you can now have up to 8 alarms with repeating functions.
Main features:
- shows current time, date and detailed information about home and
destination city
- change current time, time and date format, system time etc.
- change your home and destination city anytime with ease
- manage up to 8 alarms - adding, editing, deleting
- each alarm can be single or repeated (daily, weekly, working days
etc), each alarm may have a customized sound file
- built-in database of 1158 locations and 292 territories
- allows automatic date & time change when changing home city
- contains a convenient database browser with world map showing exact
location
- database can be edited and new cities/countries can be added by the
user
- fully integrates with operating system.
You can find more detailed information and download trial version of
Extended Profiles at http://psiloc.com/
