6680 Short Cut Functions
1 replies · 2,869 views · Started 11 May 2005
I've just recieved a 6680 on the 3 network and am having a problem with the short cut function.
According to the manual I can move my most used functions i.e.Bluetooth,Profiles,Gallery....to the GO TO folder and then assign one of the left or right keys to this.So that every time I press the nominated key a drop down list will open up.Just like in the Nokia 6230,
No matter what I try I cannot move anything apart from images to the GOTO folder.Am I doing something wrong or the operating system does not allow this?
I can assign individual functions to a nominated key but not a whole list.
Any one with any ideas?
Thanks.
The "Go To" support is only available for some applications and some functions, if they have specifically support for "Go To". In other words, it is not very useful.
Instead, look into menu > Tools > Settings > Phone > Standby mode
Try with "Active standby" on and off and the different options depending on which you choose.
