hi does anyone know why i can't transfer wallpapers, polyring , javamidlets , and even normal ringtones, from my 7650 to my 7210 via IR ? 😞
anyway just for info, u can use 7210 battery in your 7650 the type is bld-2
i dont know about the capacity but it is much more ligther .
But you cant use your 7650 batt on the 7210 cause it's abit thicker.
and one more thing one of my friend alreeady sucseed using ericsson HBH-30 bluetooth handsets with the 7650!!!!
i'll ask about the deatil and post them here later :P
wow...
bluetooth audio support
that's what i'm waiting
pls ask ur friend bout it :morning: :infinity: :lilangel: :lol!: 😛ainting: :microwave: :scatter: :silly: :smilecolros: :snipersmile: :2gunfire: :eggface:
wow new smiley .... hehhehe
also bout the 7210 battery on ur 7650 is the standby time will be logner or shorter ??????
:fadein: :angel: :agrue: :bday: :robot: :black:
well the battt i hanent try it long enough to test the stanby time but it sure works , if you chechk tha nokia page, they say the capacity is 720 Mah
and the HBH 30 things surely works!!!!!
