Latest Nokia 3230 Firmware (v3.505.2)
13 replies · 17,549 views · Started 12 May 2005
Proud_Iranian wrote:Alrighty the latest Nokia 3230 is:
Last Checked 30/04/05
Nokia 3230:
RM-51
v3.505.2
30.03.2005
So go update your phones! 😉
Thanks for informing us the new firmware .is there any difference with the previous one?thanks..
R u sure v 3.0505.2 is not the same as v 3.505.2? just asking.
Well i personally dont have the 3230 yet... but hopefully soon i will!
And i certainly hope all the bugs are fixed, including the Fat Camera Effect, as well as a boost in performance! 😉
As for 3.505.2 being the same as 3.0505.2, i have no idea... you check it out yourself in the link i have typed below! But look at the date... it say 30th of March 2005!
Latest Firmware Versions:
Pretty sure its just a mistake without 0. But who knows, well hopefully it is the latest firmware. I'll be in contact with nokia service tomorrow here in finland so then we'll know for sure. 🙄
Can you please give them a bug list to fix!
Problems such as all the hanging, beeps, camera fat effect, volume, camera quality, performance, and finally 6x zoom!
You see on the specs page of the 3230 it says 3x zoom, and the 3230 phones i have seen have 3x zoom! But if you go to www.forum.nokia.com/3230 it says the phone has 6x zoom! Where the page before mentioned it had 3x zoom!
Could it be a typo, or could it be that Nokia has increased the zoom level in its upcoming firmware for Nokia 3230? 😉
I have this firmware but it is dated 19.2.05 this still ok, or do I need to get the latest firmware?
I have 2x zoom in the original camera. But i use PhotoRite software which gives me 8x zoom.
themafia.69 wrote:is the beep fixed?
Are you refering to the 'beep' that sounds b4 any phone call or message??? If so.. frustrates the hell out of me too. I attempted to either delete or alter the 'warning.mp3' file in the phones system memory, but it appears to be locked/uneditable. Bugga!
I checked my phones firmware:
V 3.0505.2
19-02-05
RM-51
plz help i have 3230 nokia and there is a problem with ring tone volume is very low and i tried to looking for some thing to help me but i found RM-51.pm file as a solution but i have n't any Ide about to install
please help me
