I have an A920 flashed to A925, bluetooth is enabled, however the phone doesn't appear to have a DUN BT profile.
Is this correct?
Is there anyway for a PDA to connect via BT to the A92X in order to connect to the web?
Is this correct?
can you send me how to cange my firmware because I have the new firmware and the pst with crak but I don't know how to use it and you have done it!
send to: [email][email protected][/email]
skearon wrote:I have an A920 flashed to A925, bluetooth is enabled, however the phone doesn't appear to have a DUN BT profile.Is this correct?
That is correct.
No.
Is this due to hardware or software limitation?
If software I presume this could be fixed
Is 30.80.20 the latest firmware?
skearon wrote:Is this due to hardware or software limitation?
Software.
Sure, if you have the source code to the firmware. Motorola and 3 doesn't have any plans on releasing any new fixed firmware. I suppose this is because they want to sell more A1000, which does have the DUN profile.
Yep. You may have read something about 30.80.25. That is a hacked firmware originating on polish forum for Symbian phones. The changes are merely cosmetical (A1000 skin, etc.) so there's no point in installing it in hopes that it will fix any bugs.
