I've tried several times to install this program but am unsure of what it's doing to pop an error. It gets to the point where its trying to configure COM ports and then pops a 1953 error. Anyone know what that is? I'm running XP Pro and my hardware should be more than adequate to run the program. Any ideas?
Problem installing PC Suite 6.41
Lov2Drift wrote:I've tried several times to install this program but am unsure of what it's doing to pop an error. It gets to the point where its trying to configure COM ports and then pops a 1953 error. Anyone know what that is? I'm running XP Pro and my hardware should be more than adequate to run the program. Any ideas?
PC Suite 6.41 is old, install 6.5 from www.nokia.com/pcsuite. If you still cannot install, check if you have some antivirus programs or spyware programs running. Close those, it may help
