My SX1 keeps rebooting itself...
4 replies · 2,749 views · Started 12 May 2005
New poster here, but I couldn't find anything relating to this!
Basically, my SX1 reboots itself continuously. The frequency of each reboot appears to be a bit random... sometimes, it'll turn back on, then night on immediately reboot again, sometimes it'll wait a minute or two. What should I do next? :S
Any other info you might need, feel free to ask!
Thanks,
/Jas -Would rather be in the pub, but unfortunately at work :|
I have the same problem.Are you running your phone on firmare 12.That is the problem i think.Just wait until new firmware version copmes out.
spusibrk wrote:I have the same problem.Are you running your phone on firmare 12.That is the problem i think.Just wait until new firmware version copmes out.
TBH, I can't really check what version of the fw I have, as the phone won't stay on long enough! Suffice to say tho, I got the phone around April last year, here in the UK (from Selfridges, no less! Ooooh! Get me! :P), so I'm guessing that's prolly v6 or something?
Tried formatting the phone last night, but the * and # keys didn't seem to do anything when I turned the phone on...
/Jas -Hmm...Yeah!
Dear,
Do you install MsDriveE ? I have same problem with my SX1 Firmware14.
to solve try to clean everything you installed before by pressing & holding
"#" & "*" & TurnON Keys when you want to turn on phone.
Best Regards.
