N6680 freeing phone memory (page 18 on the manual)
4 replies · 3,082 views · Started 13 May 2005
I already search about it but sorry, can't find the answers.. 😡
Ok, did anybody tried the item highlighted in red??
Basically, i want to move only the message that i want, not all. But when i do the below instructions, didn't show me the 'memory card' option.
On Page 18, it says:
To free phone memory, transfer data to a memory card in
the file manager. Mark files to be moved, select Move to
folder > Memory card,
and a folder.
To remove data to free memory, use File mgr., or go to the
respective application. For example, you can remove the
following
� Messages from Inbox, Drafts, and Sent folders in Messaging
� Retrieved e-mail messages from the phone memory
� Saved Web pages
� Saved images, videos, or sound files
� Contact information
� Calendar notes
That is little bit misleading.
You can only copy or move the whole Messaging database between the phone memory and memory card.
Use Messaging > Options button > Settings > Other > Memory in use > here switch to the memory card (select your Memory card name). That frees your memory.
no u have to tell it when it asks you copy messeges to memory card? say yes, then when it asks you leave it on the phone memory you say no, that will free up space, because if u leave it on the phone memory you will just have copied it to the memory card thats all
themafia.69 wrote:no u have to tell it when it asks you copy messeges to memory card? say yes, then when it asks you leave it on the phone memory you say no, that will free up space, because if u leave it on the phone memory you will just have copied it to the memory card thats all
OK, only moving can free the phone memory, I know. The reason why I mentioned both copying and moving was that evillajr asked following:
evillajr wrote:i want to move only the message that i want, not all.
So I tried to explain that it is only possible either to move all (not keeping anything in the phone) or to copy all (keeping everything also in the phone).
petr wrote:That is little bit misleading.
thanks..
at least somebody agree that it was a bit misleading.. thought my unit is having a problem.
nokia folks also dont know what to say when I ask them. 😉
