I've realised that the ringtones on the 7650 are really lame,
Good ringtones are hard to find,
here are sum polyphonic ringtones that i feel are decent :P
Polyphonic Ringtones
has anyone got the following: 😃
Nelly feat. Kelly Rowland - Dilemma
P. Diddy feat. Usher & Loon - I Need A Girl (Part I)
P. Diddy feat. Ginuwine, Loon & Mario Winnas - I Need A Girl (Part II)
For Midi ringtones check out: www.mididb.com
But if you want REAL ringtones, get a mp3 file, convert it to WAV (search the net for some programs) then edit the wav file using Windows Sound Recorder (that app that comes with every windows!😊) and then change the quality to less, like 44.000 KHz 8 bit mono i guess, and 7kbps, and then you got the perfect LOUD (if you save the file after editing on high volume) ringtone!!
Or,even better,you can use Nokia's multimedia convertor.
Ghostdog where can u find or buy the Nokia's multimedia convertor? :-?
if you convert mp3 files and then change the quality it makes the tune crap, even when u put the volume high,
whats the Nokia Converter & how do u get it?
Well, you can also try looking for midi at www.findmidis.com :fadein:
[quote="Sonic"]has anyone got the following: 😃
P. Diddy feat. Ginuwine, Loon & Mario Winnas - I Need A Girl (Part II)[/quote]
here is the song dilemma - nelly
Nokia's multmedia program just makes sound and video clips smaller.
i converted a 192kb mp3 that was 8mins long to 1.6megs and i play it through my phone, the quality is much then original but not noticeble on the the 7650 speakers.
it converts to .wav btw
i have attached the program.
where can u find or buy the Nokia's multimedia convertor? :-? 😮
I seriously nee dto personalise my phone and i dont know where to get the proper ring tones to do it! Help me 😞
It's available on Nokia's 9210/9210i page
Not necessarly! I converted a Mp3 file to WAV, then changed the quality to the best KHz, but lowest Kbps, and mono at 8 bit, and it was REALLY good quality. Besides, you can't expect MP3 quality at a really high volume, as someone already mentioned on this forum: its a small speaker, you can't expect a Bose 5.1 3D sound surround on your phone!!
Try it, it worked great here, i tried different mp3's, and they worked smoothley. ONly BIG downside is that it takes alotta space. A 8 second WAV ringtone on the settings up there it like 400 kb!!!
But worth listening!
thanks to Kietysack for the tone, it sounds good
to 555
u say you have attached the Nokia Converter but i cant find it, there aint any attachment?????????
isn't nokia convertor only for the nokia 9210 etc???
[quote="Kietysack"]isn't nokia convertor only for the nokia 9210 etc???[/quote]
It work also with 7650...
Here is my ringtone made with sound blaster wave studio and converted with Nokia 9110 wav converter...
shit I can't send it.. it takes 270kb and the limit is 256kb...
compress:ed takes 259kb :cry: :cry: :cry: 😞
With that 270kb on your phone you can get 35sec music with voice, bass etc.
thus the bass isn't that good 😃
Here is nelly which i use for my ringtone
had problems attaching, and still can't attach arrgghhhh!!!!
still cant find the Nokia converter!!!!!!!
sum 1 help,
can sum 1 post the link
Thankz
[quote="Sonic"]still cant find the Nokia converter!!!!!!!
sum 1 help,
Thankz[/quote]
Here is the link to the Wav converter that I use to do ringtones:
http://www.nokia.com/phones/productsupport/9110/downloads.html
It's in the bottom of page 😉
