I can`t backup my contacts from my phone, even when I use Nokia PC Suite theres an error: "Cant copy C:\System\Data\Contacts.cdb"
I tryed to send it via Bluetooth using Handy file but theres also an error saying: "already in use"
Any sugestions?
Any sugestions?
Have you looked at the 'sticky' thread in this forum? It may be of some help...
I was just found that out u can use a app called SmartVCard and do u know how to bacjup gamesaves on n-gage QD
Make sure you have the contacts program closed when backing up via PC Suite. You might want to try doing this immediately after restarting the phone.
Rafe wrote:Make sure you have the contacts program closed when backing up via PC Suite. You might want to try doing this immediately after restarting the phone.
Thanks Rafe, after restarting phone it worked.
