Ask for lock code when rebooted?
5 replies · 2,365 views · Started 13 May 2005
Hello,
I believe my 9300 used to ask for the lock code (and the PIN number) when I reboot by removing the battery and reinserting it. It just doesn't do it anymore! It only asks for the PIN number now! Any ideas? Am I missing something or was I dreaming?
I have the following security settings and I'm runing system ver. 4.53:
Autolock period: None
Lock code: *****
Lock if SIM card is changed: on
Allow remote locking : Yes
Remote locking works.
Thanks in advance for any help.
marlin wrote:how does remote locking work?
Answer the question with a question?! 😊
It's simple. Go to Control Panel > Security > Device security and enable "Allow remote locking" and set a password or a phrase.
Now if you send a sms to *your* phone containing that phrase it will lock the phone and acknowlege that with a reply to you (to the phone you used to send the sms from).
Just keep in mind that the MMC card is locked with the first 8 characters of the password you set.
I hope this helps.
WST wrote:Hello,
Lock code: *****
Lock if SIM card is changed: on <----- Here is the secret !
It will ask for the lock code only if you insert a different SIM card.
rtamas wrote:It will ask for the lock code only if you insert a different SIM card.
Thanks for pointing that out and solving the mystery and returning my confidence in my sanity 😊
