Connecting BlueTooth Headset to 6620
2 replies · 2,038 views · Started 13 May 2005
Im sure im doing something wrong.. but i cant get my bluetooth headset to work with my new 6620.
It pairs fine.. but i cant figure out how to get it to work. How do i get it to play mp3s over the headset or even route the calls to me headset?
Could someone post a walkthrough to how to connect a BT headset? and how to set it to receive calls etc?
Thanks!
You need to make sure the headset is connected (depending on your headset model this can sometimes need to be done implicitly).
Depending on the model MP3 may not play over it.
If the headset is connected calls (both outgoing and incoming) should automatically use the headset.
Note also that the Bluetooth headset must have support for the Bluetooth handsfree profile. If the headset only supports Bluetooth Headset profile, it will not work with the phone. Most headsets today support both profiles, but older ones might only have the headset profile, which, as I said, is not enough.
