Hi im a newbie in this kinda stuff so..
how do u install mp3 in ur n-gage?
do you need a MMC card to store mp3 ringtones?
How do you activate mp3 ringtones on n-gage classic?
You dont have to install mp3 on an mmc but because they take a lot of space a lot of people do. If you have a small on you would like to use you need to send ito your phone (via PC Suite / cable / Bluetooth).
Serialbox wrote:Hi im a newbie in this kinda stuff so..
An MMC is required to store MP3s upon. Once you've gotten the MP3 onto the memory card, open the Menu, go to Profiles, choose a profile and select Customize. There, you will be able to change your ringtone. Just locate the name of your MP3 in the list, and voila, you're done.
PsychoPunk wrote:An MMC is required to store MP3s upon. Once you've gotten the MP3 onto the memory card, open the Menu, go to Profiles, choose a profile and select Customize. There, you will be able to change your ringtone. Just locate the name of your MP3 in the list, and voila, you're done.
ThX dudE ! 😃
that aint right mine dont recognize mp3 files only wav and rmv or sumtin like that..
What if you put them in c:\Nokia\Sounds\Digital or e:\Sounds\Digital?
i tried putting it in the digital folder, it still doesnt recognize...
Have u try to restart ur phone after put the sounds? Try with safe mode (hold the pencil key while booting).
