hello all,
i have been searching forums and contacting tmobile n motorola for help and i still cant get anywhere!!
I recently got a a920 which has already been upgraded to the a925 software.
Im trying to get connected to GPRS/WAP for my tmobile (uk) sim. I got a reply from t mobile which said...
Below is a list of generic settings, it may be possible to enter these into the WAP and MMS settings menu, however, T-Mobile cannot guarantee that these services will be supported if you are using the Motorola a925. You may not have all the listed menus, as they may differ from phone to phone.GPRS settings:
Connection Name - T-Mobile GPRS
Homepage - http://wap.t-mobile.co.uk
APN - general.t-mobile.uk
User ID - user
Password - one2one (in lowercase)
IP Address - 149.254.001.010
Authentication - Normal
Connection Security - Off
Session Mode - Permanent
Prompt Password - No
DNS Address - This should be left blank
Response Timer - 150 seconds
Show images - Yes or On
Data Mode - Connection OrientedMMS settings:
Homepage - http://mmsc.t-mobile.co.uk:8002 WAP IP - 149.254.211.10 Port - 9201 Timeout - 1 Minute CSD No. - Leave Blank Username (MMS) - Leave Blank Password (MMS) - Leave Blank Speed (Bps) - 9600 Line Type - ISDN GPRS APN - general.t-mobile.uk User Name (GPRS) - user Password (GPRS) - one2one (in lowercase)
the settings dont match and i have tried several different combinations. All i want to know is if anyone has managed to get a a920/a925 to work with tmobile(uk), and if they did, what settings.
thanks in advance for any help!!
