When i try to install games by clicking sis files, the program crashes when trying to move them to the a920. Dunno what to do. Im new to the system so anything I need to read up on? Im using usb.
Also the harddrive on the a920 is split into 2, one c: drive with 10megs and 1 d: drive with 30 megs. Can only see media files with the program "my a920" and my
camera only puts files on c:
Any way i can catagolize my files from the a920?
Its difficult to diagnose this without knowing more. It may be that your PC Suite installation has a problem, or it maybe the sis files you are trying to use.
You could try getting hold of a PC card reader for you memroy card and copying things across directly using that. (Copy the sis files directly onto the card and run them from the phone). You should also be able to send file by Blueooth (if it is actiavted on your A920).
Once you have a file manage installed it should be easy to move things around (e.g. move picture files). There may also be a setting that specifies where the camera applications saves it files too (change this to D: obviously if you wish).
