Do you need a MMC card to install FE Explorer?
4 replies · 4,675 views · Started 14 May 2005
Do you need MMC to install FE explorer?
or just install it without mmc?
i also dont know how 2 install FE Explorer
Plz help me im a total newbie
No, you don't. If your PC has Bluetooth, just turn Bluetooth on on the phone, too, and send it over (on Windows you right-click on the file and choose Bluetooth from the "Send To" menu).
You can also use PC Suite's Application Installer, if you have it already set up (also needs Bluetooth with the N-Gage).
N/A wrote:No, you don't. If your PC has Bluetooth, just turn Bluetooth on on the phone, too, and send it over (on Windows you right-click on the file and choose Bluetooth from the "Send To" menu).
Im using N-GAGE classic so i just use the usb cable?
where do you move the FE EXPLORER file to ?
Serialbox wrote:Im using N-GAGE classic so i just use the usb cable?
you can't install it if you use the usb cable without a mmc card
Right. With the N-Gage classic and USB cable connectivity, you can only see the MMC of the N-Gage on a PC. If you have no MMS, the USB cable won't be useful for anything.
If you have an MMC, put the .sis file in the root (top) directory/folder on the MMC and use the "Manager" app on the phone to install it.
