questions for plinkykev
6 replies · 1,668 views · Started 15 May 2005
hi plinkeykev
i m from belgium my english is not so good
questions are
is it normal that my sendo x is running slowly
is it normal that my sendo stuck sometimes
do i have the latest software x1.109.5.2
release IG
26 nov.-2004
pn:8g26-00000-00934
spn:0000-00000-00000
sendo 2004
ig:3.4
ig:dangaard 1.11
i cant receave tel calls when i juse route 66 on my sendo x
sendo_ray wrote:hi plinkeykev
questions are
release IG
26 nov.-2004
pn:8g26-00000-00934
sendo 2004
ig:3.4
ig:dangaard 1.11
First, no problem with the English!
Slowly - I would need more details really:
how is it slow? what program is being slow? are other programs running at the same time (press and hold menu key to see)? how much RAM is left (see Extras / About / pane 2)?
Stuck - Again, more information is needed.
what gets stuck? what program is runnning? etc
That firmware is the latest version. A new one is being finished at the moment, so I hope that will be out soon.
Route 66 seems to consume a lot of RAM. The box says about 2MB, but my version uses a lot more than that. I can get phone calls still though. It may be beacuse other things are running?
I hope that helps, but for some things, I would need more details.
Regards,
pk
Use Taskspy or something similar to see what background apps you have running - the 5Mb of RAM should be fine for most apps. I can't really comment on the GPS issue (yet 😊 ).
questions are
release IG
26 nov.-2004
pn:8g26-00000-00934
sendo 2004
ig:3.4
ig:dangaard 1.11
Hi Sendo_ray
I assume you also bought the Sendo + route66 pack in the Carrefour store.
The Firmware version is the latest, it has a strange version number because of some sort of adaption for our network.
This is what Plinkeykev told me in another post of mine.
I experience no slowiness when running route66 except from slow startup of route66 but i think that is kinda normal. I receive calls during navigation.
Have not really a big problem with the Sendo, with me it's quite stable.
Greetzzzz
plinkykev wrote:Hi,
Regards,
pk
hi
when i puch contacts i have to whait over the 5 seconds
when i call some one it takes minimum 15 seconds to get the first ring
some times i cant recieve tel call then i have a message (you mist a call)
the phone get stuck no program is actieve then i restart the phone.
thanks for the replys every one thak you.
dvdke wrote:Hi Sendo_ray
Greetzzzz
hi dvdke
are you from belgium do you speak dutch
leth me plz know
sendo_ray wrote:hi dvdke
leth me plz know
Hi Sendo_ray,
Yes I speak dutch and I'm from Belgium 😉
Greetzzz
