better Notepad for S60?
1 replies · 1,883 views · Started 15 May 2005
hi,
is there any advanced notepad application that works with the built in notes database, hence the notes are flawlessly synchronized with outlook?
this, let's say notes+, would allow some more advanced features such as find/replace, undo/redo, and most important the font will be smaller, thus allowing to see more text on the screen (e.g. the same font in the SMS application is used)
due to the font size (which is big) is the built-in application almost unsusable ..
is there anything like this ? if not the case, I'm sure it would sell well if someone developed it ..
There isn't anything that I know of (memory might be dodgy though). I agree an advanced Notes program probably would be quite popular.
