Flash pluagin for the nokia 9500!
2 replies · 2,305 views · Started 15 May 2005
Is there any such thing, and maybe shockwave plugins and so on for the web browser?
Are there other browsers for the 9500?
I can view Flash sintes on 9500 as well without having installed it. Probably opera still uses a plugin for Macromedia powered sites..
Playerkiller wrote:I can view Flash sintes on 9500 as well without having installed it. Probably opera still uses a plugin for Macromedia powered sites..
Opera for the 9500 supports Flash 5. However, it is preinstalled, and any you can�t add any plugins as far as I know.
http://www.macromedia.com/mobile/supported_devices/#nokia
If it doesn�t work, this might be because someone has turned the plugin option off in the browser settings. Check if plugins are enabled or not.
So far there are no alternatives to Opera on the Nokia 9500.
