Nokia 6260
5 replies · 2,534 views · Started 18 May 2005
Hi guys,
Can ne1 let me know how to turn GPRS off manually. Because when I 'm using GPRS and dont disconnect it chew up all my battery. I need to know how to disconnect it.
Kris
On the standby screen press down and keep down the red/disconnect button until GPRS disconnects.
When u r connected and in any page, u'll see OPTION on the left bottom corner. From there, go to ADVANCE OPTION and then select DISCONNECT from there. U r outta GPRS!!
I dont know any shortcut key for that... Anyone????
And you can also go to menu-connections-connection manager. There are that connection and u press C-button and press yes.
or
if you want turn off the gprs, like it only gets on when you go to web, you go menu-settings-connection-gprs-gprs connection and change it to when needed 😊
hey guys,
i had a question, i got the tom tom navigation software and am wondering if i need any sort of adapter to work the navigation as some people told me u dont, yet sum people said u do???.. can u help me please?
Also does anybody know how i can get the software on my rs-mmc card?
