Syncing IMAP folders
2 replies · 2,974 views · Started 18 May 2005
Dear all
thinking about upgrading my Netbook to a 9500, and have pretty much sorted out all my queries (thanks to this forum and 3Lib) but for this one:
Can you sync more mutiple folders when using IMAP? I have been using Treo 600 smartphone with a very nice application called "Snapper Mail". This allows you to map local folders to the folders on the mail server. I use it to keep my sent mail synced. Can one do this on the 9500? I've searched this forum, and I've downloaded the manule and am non the wiser!
DT
Short answer is yes ! 😊
I use mine to sync to my exchange server and I have loads of folders setup in my mailbox and I only sync the ones that I need !
enjoy .
