Customserver for sending sms?
0 replies · 1,489 views · Started 18 May 2005
Hello,
i�m reading the book programming pc connectivity applications for symbian os and found the example which use a customserver on the smartphone to create and send an sms with the message server and mtm and an application on pc to enter the recievernumber and the text of the sms. from pc these data are sending over a bluettoth connection to the smartphone where the customserver create a sms and send its. My problem is i can�t build these example. Have anyone buildt it and can run it? Thanks for help
