Help! Reason code: ViewSrv
6 replies · 3,103 views · Started 18 May 2005
Someone can help about this?
When I press "Web" button on my 9500 Comm. , comming first:
"System:Unable to find the specified object."
and then:
" Program: Web
Reason number: 9 "
Anyone have any idea what's happening?
Thanks in advance !
Hi, welcome to the forum.
Does a battery-out reboot help? If not, you may have to reformat the C: drive. And if that doesn't help either, you need to take it down to a Nokia service centre to get the firmware flashed.
Raven wrote:Hi, welcome to the forum.
How can I reformat C:drive?
Thanx a lot
Remove the battery and leave it out for a few minutes. Then reinsert the battery and press and hold Ctrl+Shift+F during start up. You will then see a screen asking if you want to do a format.
Raven wrote:Remove the battery and leave it out for a few minutes. Then reinsert the battery and press and hold Ctrl+Shift+F during start up. You will then see a screen asking if you want to do a format.
Thank a lot,
one more quest. ,how can I see what firmware is in my phone, & how can I upgrade if its 4.44 to 4.51?
Thanks in advance!
There are three ways to check what firmware your Communicator is running.
1. On the phone/cover side type *#0000#
2. On the communicator/PDA side go to the Telephone application and type *#0000#
3. Go to Control panel - Extras - About product and scroll down to the bottom
To upgrade the firmware you must take your phone to a Nokia service centre.
Raven wrote:There are three ways to check what firmware your Communicator is running.
Thanx again,
Is there any other way to upgrade the firmware then Nokia Service centar?
Is there any link to list all codes (like *#0000#), and its functions?
Tnx in advance
