If i install MP3 playing software on my Nokia 6600. Will i be able to use mp3's as ringtones?
Also does anyone know what the maximum Capacity size memory card i can use with the nokia 6600
You cant use mp3 as a ringtone unfortunately but you could try using oggplay it allows you to have music as a ringtone. Have you tried encoding mp3's to uncompressed wav then open it in windows sound recorder then change the settings to gsm at 44khz 8kbit mono and save it. it should works on your phone and it should be a reasonable file size with good quality.
As for mmc size i think 1gb is the highest.
All you had to do was look around a little. There are quite a few stickys with tons of info. Read around before you post next time...
what you need is Nokia Multimedia Converter Pro this converts mp3, wav to amr which willwork an you n6600 and it also converts video from mpeg, avi, mp4 to 3gp files for you n6600 also....
