HELP on Nokia 6260 and Dell Pocket PC
1 replies · 1,940 views · Started 19 May 2005
Hi there does anybody know how to setup GPRS so that I can access internet and recieve emails VIA Bluetooth to my 6260 Cell. I would like to access my email through my Dell Axim Pocket PC through my Cell. I have tried different strings, dial up numbers BUT NO LUCK. I am going crazy. I have the Data PAckage from Fido and have Pocket PC from Dell and Nokia 6260 Mobile. PLEASE HELP...
ThanksHELP ME WITH NOKIA + FIDO + DELL AXIM
Step 1: Pair the phone with the PDA.
Step 2: Create a dialup setup on the PDA selecting the Bluetooth modem/phone. Use *99***1# or just *99# to make a packet data connection.
Step 3: If it isn't enough, on the PDA, define an additional modem initialization strings as +cgdcont=1,"ip","internet"
Step 4: If those aren't still enough, check that your operator supports the use of an Internet Access Point, and that it is named "internet" (or use whatever name they say you should use), and that your plan/package/subscription allows full Internet access, and - if necessary - the operator's systems show that it has been enabled for you.
