Hi guys and gurus,
I'm wondering if I can change the ringtone for my 7650 alarm. The default one is too soft even though volume set to highest. Been using my hp as alarm clock for morning call. Any ways to set the alarm as repeating... say at 7am everyday? Sorry for a relatively noob question but been searching hi and low for such options to no avail. Thanks in advance 🙄
No, on the 7650 the clock alarm cannot be changed. In newer phones it is. The clock also doesn't have a repeatable/multiple alarms. As a workaround you can use the calendar and recurring events there.
N/A wrote:No, on the 7650 the clock alarm cannot be changed. In newer phones it is. The clock also doesn't have a repeatable/multiple alarms. As a workaround you can use the calendar and recurring events there.
Thanks buddy for the reply.
Is there any (external) symbian software around that can do the trick? 😊
