Hands free on 9500: Does the screen really need to be open?
2 replies · 3,060 views · Started 20 May 2005
I've often thought about this...
Especially on the 9500, where the speaker & the mic are both on the outer edges of the phone. (Thus the ability to play sound, & pic up sound via the mic, are not inhibited by whether the screen is open or closed.)
Whats the point of being forced to have the screen open, when surely once one has answered a call, one should simply be able to press a function key on the front to go to 'speaker'. (Lesser phones like the 3650 & 6600 could do this.)
I understand that it may not be as good on the 9300, as the speaker is semi covered when the screen is closed.
But this is the 9500 I'm talking about, & it is very different in that regard, thus perfectly capable in theory of making & taking calls hands free, WITH the screen CLOSED. Being forced to have the screen open & lit, is just a waste battery life.
Of course, it should still work hands free if the screen IS open (as there will be times you need to get to information etc...), but the phone should really be able to give the choice on the 9500.
It would surely only need a change in the firmware to add this capability?
xoio
I'm guessing it's just that it's legacy functionality. The speaker grille on the 9110/92x0 was next to the keyboard so you "needed" the unit open to use speakerphone. I'm guessing Nokia left it as is as 9xxx series users would be used to this function.
Hmmmm
Well personally i hope they change it to add the capability, which, as said already, would only requre a tweak in the OS via a FW upgrade.
xoio
