6680 latest software revision
20 replies · 12,816 views · Started 20 May 2005
Vicky wrote:I am Using V 2.04.15
Wht Abt yours
Its the Frist Version.
yes, im also using the same version. i just receive a message from my provider that a new software for 6680 has been released. i'm going to nokia care and find out whats new in this revision, if it is worth to upgrade.. inform you later
themafia.69 wrote:yeah inform us please, and try to get a change log from them
yes.. confirm! there's new software revision for N6680. i just sent my one for upgrade. dont know the revision number yet, they took my unit and will be collected tomorrow. will keep you posted..
Got my 6680 about 10 days ago from vodafone.
Firmware Version is
V 3.04.11
14-04-05
RM -36
Dont know if this helps.......
Just one week before i upgrad my 6680 in Chennai India Thru Nokia Care. New firmware version is
V 3.04.37
01-06-05
RM-36
Kannan M
mk_kannan wrote:Hi,
V 3.04.37
01-06-05
RM-36
Kannan M
Anyone have any idea what the Changes/Benefits are for upgrading Firmware
Doc wrote:Anyone have any idea what the Changes/Benefits are for upgrading Firmware
New features released in SW v3.04.37:
- New RAM memory management scheme to improve phone behaviour in
low memory situations when using multiple applications at the same time.
For pre-defined applications a defined amount of RAM will be freed on
start-up (Browser, Video telephony, Java, Real One Player) to ensure
application start-up.
- Browser cache (present in phone RAM memory) will be emptied when
exiting browser
Changes/improvements made from MCU SW v3.04.11 to v3.04.37:
- Bluetooth
- Interoperability with Sony-Ericsson BT headsets improved. Sniff-mode
timer value used in phone changed from same value as used in SE
headsets to prevent headsets from disconnecting
- Browser
- Browser now correctly identifies Simplified Chinese as accepted
language in accept headers if this is selected as phone language
instead of traditional Chinese
- Behavior of internal rendering changed to improve performance with
pages containing animated images. Identical animated image frames
are no longer stored separately to reduce number of entries in cache
- Previously visited links no longer become white and unvisible, if
scrolling down a page with background image
- Nokia Lifeblog registering improved
- Camera
- Problem of not being able to continue using camera application when
in standby mode corrected
- Clock
- Alarm tone ascending volume tuned
- DRM
- DRM combined delivery xml parser functionality improved
- Missing DRM rights now correctly shown
- Content is now correctly interpreted with combined delivery file that
includes a linefeed (CR+LF) inside the constraint part of the rights
object improved
- Notification now shown correctly when WAP Push rights object
received for OMA DRM separate delivery content
- E-mail
- Occasional problem of not showing imap4 email folders corrected
- Gallery
- Improvement in handling of very long play-list names.
- Java
- Problem in interim PR1.1 release(s) corrected. Java audio tone
playback control changed, tone speed was incorrectly set and speed
of playback was too fast in some cases
- Java VM now returns correct language ID string for Thai instead of
NULL string.
- SMS
- Receiving SMS containing more than 45 Unicode characters no
longer causes shorter standby time in idle state if messaging centre is
left open in background
- Recorder
- Recording audio during voice calls improved.
- Streaming
- Stereo is set as the default for audio channels. This enables playing
files where the number of audio channels is not specified.
- Robustness of Real One Player improved to handle files where audio
part is shorter than video part
- Improvements when continuing the streaming after interrupted by
voice call in network mode 1 conditions
- Improved functionality with scene changes
- (U) SIM
- FDN handling improved in some error situations
- UPIN is now requested to enter when UPIN is activated instead of
PIN
- (U) SIM ATK
- Play Tone command playback volume increased
- Video Sharing
- Uninstallation of Video Sharing application is now possible
- Video Telephony
- Interim problem in PR1.1 release corrected, interoperability problem
with Alcatel Video Mailbox corrected
- Improvement in video transmission stability
- Occasional picture overlapping problem when calling to video mailbox
corrected.
- WCDMA
- MO Video Telephony call setup improved in Siemens RAN, when
simultaneous data transfer ongoing. �Network busy� no longer
displayed
- IMEISV sent to network changed to 16
- Automatic access point settings updated for some operators
- Operator names stored in device permanent memory updated to reflect
latest status
- USSD channel closing behavior changed. Now it is possible to receive a
new USSD message after timer expiry for USSD connection
- Functionality with some pre-pay SIM cards improved, USSD
acknowledgement handling modified
- User is now better informed if MMC formatting fails
- Corrected the problem that very short audio clips were not played at all.
- RS-MMC card access timings modified to improve handling of spesific
defective RS-MMC card
- Improvement to play some defected MIDI files
Sourse: Nokia
mine is 3.04.13 and I'm here in U.S
where can I get it flash to .37?
The phone was from Hong Kong, not purchased here in U.S
Dear Hassan,
Thanks for the highlighting the latest software for Nokia 6680. Can u pls tell me from where can i download this firmware ? I tried from Nokia but its bit complicated for me. I am noivce in this feild of Nokia 6680. I have version3.04.11 RM 36. Is it worth installing the latest version.? Thanks
Mrs.Taru
Hassan wrote:New features released in SW v3.04.37:
exiting browser
- Bluetooth
- Browser
- Camera
- Clock
- DRM
object improved
- E-mail
- Gallery
- Java
NULL string.
- SMS
- Recorder
- Streaming
- (U) SIM
PIN
- (U) SIM ATK
- Video Sharing
- Video Telephony
corrected.
- WCDMA
displayed
latest status
Sourse: Nokia
taru wrote:Can u pls tell me from where can i download this firmware ? I tried from Nokia but its bit complicated for me.
Without breaking laws (legally) you can't download it from anywhere. Firmware files are copyrighted by Nokia and as things are today, they are only distributed to authorized Nokia service/repair centers.
And the files alone without relatively expensive flashing equipment won't do anything for you, anyway.
So, locate your nearest Nokia service center and take/send your phone there for having it flashed with whatever is the latest firmware version for your phone.
I have a phone shop, i get latest firmwares from Nokia.
You need a proper equipment to update fw on Nokia phones. You just cant download and do it your self at home.
Nokia service centre can do that for you.
CPW are bit slow to get latest fw.
