Great site shame about phone no not really i lik it just annoying bugs Q1 I cannot change Euro ratio in converter the box is blocked now it is in i could do with it anyonee know how Q2 also can anyone help with realplay cannot seem to load anything on from pc is it my windows xp...thanks
minor problems
With Realplayer, are you trying real files created for the 9210? If so how are you transfering them? If trying to "install" them with PC suite don't - just drag and drop them and make sure they have the extension of .RM and not .RAM
<TABLE BORDER=0 ALIGN=CENTER WIDTH=85%><TR><TD><font size=-1>Quote</font><HR></TD></TR><TR><TD><FONT SIZE=-1><BLOCKQUOTE>
On 2002-01-01 2223, Anonymous wrote
...Q1 I cannot change Euro ratio in converter the box is blocked now it is in i could do with it anyonee know how </BLOCKQUOTE></FONT></TD></TR><TR><TD><HR></TD></TR></TABLE>
Change your current currency to something else than Euro.. i.e GBP or something, and then you can change Euro ratio to that GBP..
Regards
JeP
