hai iam new sendo x user
2 replies · 1,913 views · Started 21 May 2005
Hai,
Iam a new sendo x user , iam happy with its performance , iam using the new firmware .I have some doubts , how can i delete the sms reports.When i play mp3 songs iam not able to recieve calls .Is there any player or a way to recieve calls while playing music please help me
venkat_t3 wrote:Hai,
You can't delete SMS reports directly, however the phone deletes them as it needs to (it only stores 20, so when the 21st report comes in, it automatically deletes the 1st report).
Not being able to receive calls while playing MP3s is a known problem which Sendo are investigating. I can't promise you that they've fixed it in the next (due very soon) firmware, as I haven't heard about it from them. However, a couple of things which seem to reduce the likelyhood of it happening are:
Set the phone's network band mode to 900 / 1800 instead of automatic
Increase (if you can) the delay before your calls are sent to voicemail (unreachable / unanswered divert settings)
The problem occurs more on some networks (seemingly more on those which run on 1800MHz) than others, so, if you have the option, try a different network's SIM in your phone.
stuclark wrote:You can't delete SMS reports directly, however the phone deletes them as it needs to (it only stores 20, so when the 21st report comes in, it automatically deletes the 1st report).
Thanx a lot for the reply,iam in 900mhz network only , iam able to get calls rarely , if its just start of the song iam getting the call , else iam not able to get it.Is there a way can i set the option for reports on always , am doing it now for every message.Please advice abt other applications which i can use , am using ogg player now , any other tweaking tht can be done to this phone, if there is any please let me know
thanx'
venkat
