Webcam N6630
3 replies · 2,503 views · Started 21 May 2005
If anyone knows the procedure and apps needed to make your Nokia 6630 work as a webcam please post it here.
Thanx!! 😉
zainman wrote:try the 'search' option
Don't you think I did that?
I looked in around 6 different forums. Its all about 7650 and some other phone but that don't work for 6630.
Please don't bother to write an answer if you don't have anything to say. 😡
sad, then to learn to evaluate the search results, it is possible and you will easily find software to do it, try searching the shop too
