Car Charger
6 replies · 2,015 views · Started 21 May 2005
Can someone tell me what the output is and the pinout (eg is inside or outside + or -) for the Sendo X car charger? They are non-existant here in the US and I would think that any other mfg's charger should work provided it meets the specs. Thanks.
Mordred
Have you tried eBay? I know there's a couple of compatible 3rd party one's floating around - failing that, eXpansys have got some at a pretty good price/
Have you tried using a dvm on the mains charger? This should be able to tell you which polarity the charging socket needs...
