Problem with my RS MMC Card
2 replies · 1,843 views · Started 21 May 2005
I just need an advice and i had no one to ask and I hope to get an answer here. I've bought a 256RS MMC made by Sandisk for my 7610 and for about 1 week it worked great but now out of the nowhere i have this problem. The phone see the card but when i connect it to my desktop using the data cable that came with the phone, PC Suit doesn�t see the card only the phone memory. I've tried my 64MB card (the original card that came with the phone) and it's ok. I have reinstalled the PC Suit and the situation doesn�t change, I've switched the USB port and the cable too and the same. I don't think that is something wrong with the card because i can see it from my phone and i guess that if it was broke the phone wouldn't read it too. Is there something i can do to fix this, can anyone knows what I can do?
Thanks!
I want to ask you one thing that when you buy card then did u format the card in phone?
and u are facing the problem from that day or after 1 wwek as u wrote above
ive got this problem myself too. wad happened was i locked the mmc with my phone, u gotta unlock it[remove the lock code u set on ur phone for th mmc] and ur set to go.
if this doesnt help, try formatting the card on ur pc with the fat32.
