Adobe Reader for 6680 Compatibility??
3 replies · 4,969 views · Started 22 May 2005
Hello all...
I have just come across an Adobe Reader on the Adobe site that is intended for the N6680. (There is a link from the Nokia 6680 support page)
Would anyone know if it would be possible to use it on the 6630???
Any thoughts....
Thanks in advance
moodd wrote:Hello all...
Any thoughts....
Thanks in advance
I used adobe acrobat reader on my 6630, worked great.. I don't remember what version though.
Just download it, it should work!
I Used it on My Nokia 6680 and its working perfectly fine...
Quit Helpful Software if u put Acrobat Files.
AR for symbian works just fine on 6630. but it doesn't work on older models only on S60 2.6 and newer ones ..
