Pairing already done, but phone says can't connect when I send a file to the pc. It will work though if I send a file to the phone from the pc. Works fine with other phones (3650, 3660, P800, etc). Can anyone enlighten me? :frown:
Phone can't send files to PC via bt
Try deleting the pairing and starting again.
Rafe wrote:Try deleting the pairing and starting again.
I already did. Still wont work. Hayayay
p800se wrote:Pairing already done, but phone says can't connect when I send a file to the pc. It will work though if I send a file to the phone from the pc. Works fine with other phones (3650, 3660, P800, etc). Can anyone enlighten me? :frown:
So...let me see... your phone says "Connection error"... in the File transfer settings you should enable the "startup automaticaly"... after this it should work...
Wich suites are you using? I know that the suite from Sendo works with all s60 devices, especially with all s60 devices up to 6600. Most devices I use are synched via this app, (ngage, X, SX1 etc)
It could also be possible that some other apps are using the com-gate.
and yes, if you trie to send files to the pc via BT without using the Mrouter component this would not be accepted by the pc.
There was a mrouter update somewhere but don't know if this was for the s60 suiotes \....
