okay. i made a new folder in the menu page and i found out that i could only use numeric numbers for the file name. I tried everything and there is really no way out.
New bug discovered.
Are you saying that when you are entering the folder name, the text entry mode is forced to numeric only, and you can't switch beteween numeric/text when you press the '#' key?
Short presses should switch between "Abc" vs. "abc" and a long press to "123" vs. "Abc".
i tried. It doesn't works.Im trying it with Fexpolrer.
btw a long press on # will give me 2 ## on the folder name
yeah, i have exactly the same problem
firmware version 3.0505.2
19-02-05
RM-51
I want to create a folder in the menu with FExplorer, but what's the path to the menu? I can't seem to find it. please help 😊
You can't create a new folder in the menu from FExplorer (menu folders are not folders in the file system). Instead, you do it in the main menu by hitting "Options" and then choosing the appropriate option from the list. Only one level of subfolders under the main menu is possible.
ofcourse i know that's the normal way of doing it, but i can only enter numbers for the folder's name... (hence my question was asked in this thread!) 😉
Those who cannot type anything but numbers, have you by any chance installed WildSkinz on your phone (and possibly uninstalled it without disabling it first)? If you have, you now know why you shouldn't have. If you have already uninstalled it, reinstall it. Restart phone. Disable it. Restart phone. Uninstall it. Restart phone.
