Since no particular event or installation that I recall my 9500 has been failing to synchronize....
The settings (USB cable etc have been checked and are OK so far I can see).
The PC Suite has been removed and reinstalled but no fix.
Several PC restarts and 9500 battery removals have also taken place.
(firmware is the original 4.44)
Please note that backups and file transfers work fine! Synchronization properties appear OK.
Description of the problem following synchronization is as follows....
When I try to do so I get on the PC window:
Opening Databases, Waiting for mobile phone to send data
Both devices (PC & Commie) display the rolling synch logo
Then, first the PC gives up with:
Synchronisation Completed 0 Entries Updates
With the report stating
Warnings 1
The following warnings were produced during the synchronisation:
PC Sync information.
Which when clicked it displays:
The mobile phone has not responded.
Possible Solution
Please ensure your phone is in the Idle state showing your network provider's logo, then restart the Synchronisation.
Then the 9500 gives up with
"Synchronization was interrupted before any data was sent to the server"
Then, in the 9500 Synchroization Log I get:
"PC Suite Profile" Date nn/nn/nn Time: nn:nn:nn
System Unable to find the specified Object
Contacts(�c:/System/Data/Contacts.cdb�)
Synchronization was interrupted before any data was sent to server
Please note that the file does exist and that I went to the synch profile settings (Content TAB) and re-defined the specific file by browsing to it without luck....
The contacts file (through the contacts db works fine)
Any ideas?!!!!
Thank you,
Gregory.
