System Programs Lost
1 replies · 2,345 views · Started 23 May 2005
Hello, this is my first post in this forum, i am searching for good forums since 3 days, and finally i found it.
i removed (from manager) some programs from my mobile, i think its system programs because everytime i try to enter an appilacation i find a message: SYSTEM ERROR.
from the removed programs log i read the names of removed programs, they are:
Common Licenser 1.17
License Manager 3.00
Common Connectors 2.17
Common Security 1.17
Common Catalog 1.17
KeyLock 1.00
AutoLock 0.03
please help me finding them..
thank you a lot
Wirelessly posted (Nokia3120/1.0 (05.30) Profile/MIDP-1.0 Configuration/CLDC-1.0)
I think you should try to remove all programs on your phone and try to test your phone by removing your memory card. It should be caused by mmc. If both tests still have problem. Then the way you should do is to format your phone.
