hi....whenever i open my fone it takes so long to start my nokia 3650.... it usually appeared in a blank screen, meaning it would just put the backlight on and after a few seconds the backlight would be off already.. and after several times of trying for about an hour or more, it would open. Is reformatting my phone would help this problem???what should i do.... pls help me.... thnx....
help... im having a hard time in starting my 3650 fone
Well this is a bit weird....
Well i am not expert but iwill gonna give you some advices.....
1)try to open your phone while it charching
2)Remove your mmc and open it(because if you have installed apps there which cause problems your phone finds them)So remove it....
and 3)if you have installed apps (like these above in your phone memory)you phone needs format.........
thnx for the advice.. but i haven't installed any application on my phone or mmc... i already got the same problem a year ago, and i send my phone to nokia service center,.... I'm thinking of other ways, so that i would not send it again to nokia to save money... if i format my phone by myself, do u think it would worked????... what kind of format should i do... thnx...
Your phone needs to be formated.....Ok had you ever received a messge with bluethooth which was asking to install it?Iam telling that because *bad*people are sending viruses which are very destractive!!!Here in Greece the most known is CARIBE...Have you ever heard of that?
Ok..i dont know how you are doing format...I guess that you need the Nokia's software(for 3650),a pc program to manage files into your phone and a cable to get your phone connected to pc..............(repeat i guess)
The format doesnt cost very much..the last time i remember it cost me 20euro (in Greece)
See YA!!!!!
NUMBER ONE!!!!!!!!!!
