i am thinking of pre-ordering the 512 meg card...does it have any issue with 6630 nokia phones? anyone have the 128 256 cards??
ATP memory card are good brand?>
From what I have read previously - the actual memory chip inside all the cards are the same, made by samsung and re-branded by the different manafacturers.
I have had a 256 cards for a couple of months now and so far not had an problems.
Rgds
Will
I got my 512mb ATP card yesterday and so far it's working just great.
Mufty wrote:I got my 512mb ATP card yesterday and so far it's working just great.
can you send me a link to where you got it???
They even sent me a yoyo just to be nice..
pachi wrote:i am thinking of pre-ordering the 512 meg card...does it have any issue with 6630 nokia phones? anyone have the 128 256 cards??
Yaa.... i have already ordered 512MB DV_RS_MMC for my 6630 & i am expecting to receive it soon........ one of my mate have received 256 from ATP b4 few months & its still working just cool........... thats all i can say........
pachi wrote:can you send me a link to where you got it???
http://www.usamemory.net/512mbdvrsmmc.html
still waiting for it.........
willbrady wrote:From what I have read previously - the actual memory chip inside all the cards are the same, made by samsung and re-branded by the different manafacturers.
I have had a 256 cards for a couple of months now and so far not had an problems.Rgds
Will
This is partially true. The IC flash are not all that make up these cards, and there is actually quite a bit of variance between different cards by different manufacturers. Samsung is, however, the leading NAND Flash IC manufacturer market share wise and currently producees the best quality SLC flash, which is what ATP uses.
The ICs will help for the best performance and reliability, however, also important arethe Flash controllers used and how they are tuned. Another factor that will significantly change between manufacturers is how the ICs are packaged. The guys at auphanonline did a review on our 2GB SD card where they showed the differences in IC packaging and how it actually helps in durability:
http://www.auphanonline.com/articles/view.php?article_id=1498
-Jeff
I got a ATP 256 rsmmc and it is faster than the normal 64mb nokia card..!
Highly recommended
