MAC address of the 9500
4 replies · 5,509 views · Started 24 May 2005
Is there any way to get the MAC address of a 9500 other than reading it from the label under the battery (which is missing on mine). I was thinking about one of those nifty *# codes or something.
regards
Jowls
My wireless router allows me to view any MAC address attached to it, so briefly take down any security, connect using Web or Messaging, view the MAC's and write it down. Erm......... that is if you have a wireless router.... 🙄
Remove the battery, underneath the battery there is a sticker which gives you the mac address and the bt hardware address.
The method of reading the address from the wireless routers conf. screen worked. Thanks for the idea 😊
