Good old MultiMedia Converter Pro
1 replies · 4,272 views · Started 04 November 2002
Hi
Like many people here, I also have problems with MM converter pro. The only kind of file I qould convert to .nim is Quick Time files, and MMC is converting it since it come to processing audio, then I got "Internal Error" message!!! If there is no audio in quick time everithing work's great.
This is only kind of file I can convert. MMCPro refuses to coperate, if I'm trying to convert any other kind of file!! (mp3, wav, mpg, divx,.....)
Can someone explain me what I'm doing wrong??? How can I convert audio files to???
😛uppydogeyes: Pleeeaaaseeee!!
I think that multi media convertor requires a whole bunch of correct video drivers and stuff.
Quicktimeplayer is the worst software to install if you let the sucker continue it binds all the video and audio files to it's own shitty player.
I wouldn't be suprised if it overwrites some codecs/drivers.
Many people have had a problems with the convertor and I never heard ay good solution. All I can say is that it works for me ... and I don't have realplayer installed and quicktime and minimum ...
your best bet would be to try and converting them to avi and try to convert the avi using mmcp. This is the most basic video type so I hope that works.
Use microsoft video codec, acient codec big filesize but it could work ...
Good Luck!
